can not see the budget matrix, when I go under my budget. I think I made a mistake.
They are der when I output to Excel.
Kan ikke se Budgetposter (Budget Matrix) når jeg går ind i budgetter. Har måske trykket på en knap jeg ikke skulle. Tallene/konti er der når jeg udlæser til Excel
did you import your own budget matrix? if yes, it’s best you export first the standard budget matrix to excel. so you can see the needed format. then change that excel doc as you like and import your own budget matrix.
You have probably accidentally hidden the Fasttab Budget Matrix. Click on the blue program Icon up on the left side, left of the Home tab. Choose Customize this page, choose FastTabs, there the Budget Matrix should be available to Add. You could also just choose Restore Defaults. Click OK and then restart the page.
