I can not open:
“Setting up accounts payable parameters:” in DynamicsAx
I get an error :
Insufficient permissions to use the table parameters need to purchase (PurchReqParameters).
I have registered modules:
Company Accounts
Database Log
Domains
Electronic Banking
Fixed Assets
Financials II
Polish
Base Package Enterprise
Business Analysis
Oracle Server Database
Additional Enterprise Users
The licensing model has changed between 3 and 2009, you have not bought it so you do not get access. The obvious question is why do you need to open it when you have not purchased the functionality?
If you do not need the module which number sequence are you trying to define? I would suggest if you have not purchased AP then you will have no access and therefore no need to define a number sequence. Check with your partner regarding license changes 3 to 2009, although I would have hoped this difference would have been spotted by you in teh testing environment.
So you are using journals to post to suppliers and want to control the posting profiles in this manner? You have no access to the purchase ledger so you cannot post from there. I would suggest you talk to your partner and verify the licensing requirements for what you are trying to achieve. Without AP you cannot have access to AP, this would seem to be a loophole that Microsoft have closed from earlier versions.
