Hi, if I have a Directory C:\MyFiles, how can I from Navision see 1) How many files there are in this directory 2) Which files there are in this directory Michael
Hi Michael, you can use the internal table 2000000022::File. Create a new form to see this table. Set the filter in ‘SourceTableView’ on your folder and you will see all files in the folder. NEW Uops! I should better first read then answer.
Name DataType Subtype Length
FileSystem Record File
FileSystem.SETRANGE(FileSystem.Path,'C:\MyFiles');/
FileSystem.SETRANGE(FileSystem."Is a file",TRUE);
i:=0;
IF FileSystem.FIND('-')then begin
repeat
i:= i + 1;
Message(Filesystem.Name+' File No.:'format(i));
until FileSystem.Next = 0;
end;
If you want to filter on a file format (e.g. mp3) use this:
FileSystem.SETFILTER(FileSystem.Name",'@*.mp3');
bye Andre
