In Customized Form i wrote logic in write method which is i have to run on server side???
PurchFormLetter_Invoice invoice;
PurchID pid;
Purchtable purchtable;
CITPickUpReconcil CITPickUpReconcil;
super();
if(CITPickUpReconcil.OK == NoYEs::Yes)
purchTable = PurchTable::find(CITPickUpReconcil.PONumber);
invoice = PurchFormletter::construct(DocumentStatus::Invoice);
invoice.update(purchtable,pid,
SystemDateGet(),
PurchUpdate::All,
AccountOrder::None,
Noyes::No,
Noyes::No,
false,
true);
else
CITPickUpReconcil_ds.allowCheck(false);
Throw error(“Posting is Cancelled”);
this logic is working fine but,It should run on SERVER side…Any suggestions please…???
And the answer to my question is below…## Where and how is my code running
Performance issue can also occur when it is running on the wrong place. The next table show where the code is running.
Object |
Possible tier(s) |
Comments |
Class |
Client, server, or called from |
Tier is specified by using the class RunOn property (set to Client, Server, or Called from). |
Class instance method |
The value is the same as that for the class. |
Class static method |
The value set for the class can be overridden by using the server or client method modifiers. |
Form |
Client |
Report |
Called from |
Table |
Called from |
Table instance method |
Called from |
Table static method |
Called from |
Table kernel method (update, insert, and so on) |
Called from unless overridden |
The value set for the table (called from) can be overridden by using the server or client method modifiers. |
Job |
Client |
hi pawan ,
move u r code to table level
thanks
srikanth
