Can i make form (!) based on temporary data?
Can i make form (!) based on temporary data? Or only using ranged “Integer” table? Business Applications Programmer Sertified Navision Developer SIA “Sintegra” Latvia
I’m sure this topic has been covered lately if you just search the archives. Otherwise, you can look at the Navigate form. It probably does what you are looking for. Chris Krantz NCSD,NCSQL,MCSD,MCSE Microforum Inc. Toronto, Ontario, Canada
Form 345 does this Lars Strøm Valsted Head of Project and Analysis Columbus IT Partner A/S www.columbusitpartner.com
Yes, if you create and fill the temporary table with data outside the form and call the form with the temporary table. You can now view and edit the temporary data.
I think the form must have originally been created in association with a permanent table. It can then be called for use with the temporary table (with fields matching those defined in the form) and the temporary table’s data. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
quote:
Originally posted by daves: I think the form must have originally been created in association with a permanent table. It can then be called for use with the temporary table (with fields matching those defined in the form) and the temporary table’s data. Dave Studebaker das@libertyforever.com Liberty Grove Software A Navision Services Partner
Hi Dave, long time no talk too! Dave is quite right, the temporary table must be associated to an actual table in Navision. However, with the wealth of available tables, surely one could be found to use as a reference. Bill Benefiel Manager of Information Systems Overhead Door Company billb@ohdindy.com (317) 842-7444 ext 117
