I’ve two methods in my report design . My question is How can I call a method from another method of my report design.
Explanation: Method 1: CustUnit
Method 2: CustPrice
In my CustPrice method I want to call CustUnit method because I’m calculating Custprice value based on my CustUnit. If my CustUnit is M2 I will calculate my CustPrice=Net Amount/M2 (If my Custunit is M2, if CustUnit is Pieces then Custprice=Net Amount/Pieces)
Please I need help
I assume you are using variables in the methods to return the values?
I would use a select in the report Fetch() method:-
Select the current CustUnit and if CustUnit = ‘M2’ then do your calculation.
You then simply write display methods to return your variables on the report, i.e. ‘return CustUnit’ / ‘return CustPrice’
those two methods are display methods or any other methods?
You can simply store the values in a variable of 1st method and thus use that value in other one.
Thanks Ven,
I solve this problem.
I appreciate your response.
Thanks a lot Pankaj…
I appreciate your quick response…
