Calling form - methods
Hello,
i know that it is possible to create public methods on a form. But i don’t know how to call them (i use the formRun-Object to call the form)?
Is there any solution?
Thanks in advance,
Frank
Its possible to create public methods on a form.
1.Form run method write this
public str custmerName()
return CustomerName.text(); / / CustomerName is string control in the properties auto declaration Yes
2.Call this method in Class main method
public static void main(Args args)
str custName;
if(formHasMethod(args.caller(), identifierStr(custmerName)))
custName = args.caller().custmerName();
info(strFmt("%1",custName));
thanks for your reply.
I tried the above, but i can’t compile the solution. The line “custName = args.caller().custmerName();” produces the following error “The class ‘FormRun’ does not contain the function” (my free translation - we are using a german ax ;)). This sounds logical to me.
I call the source in a click-event from a button, not in a class (maybe this is a problem…).
Am i missing something?
Frank
call that class through Menu Items - action
in the form we can take menu Item button – properties menuitemtype action and menitemname
when ever click menuitembutton call that class
Thanks a lot, that works :slight_smile:
