Hi guys.
I am calling a data port which will export the data to the text file. The data port is based on item table.
file_to_export := ‘c:\text.txt’;
DataportObject.FILENAME(file_to_export);
DataportObject.RUN;
I want to put the filter to export the data for a particular item code. That the user selected. Like i put the button on item card form “EXPORT DATA” i will call this data port and pass the current item code number from item card from.
Create a function that sets the filters for you. Then do DataportObject.YourFilterFunction before running the dataport.
create a record variable for Item table. Apply filter on it. Then run the dataport like this.
Dataport.run(dataport number, record variable)
Thanks Matt for the reply. I have checked but still its not working fine.
Code for the function in Data Port.
Item.SETRANGE(“No.”,’%1’,var1);
Code in code unit.
val:=‘9789957086855’;
DataportObject.func1(val);
DataportObject.RUNMODAL();
MESSAGE(‘finish’);
But still it is exporting all the records can you please tell me where i am doing wrong. Thanks
BTW, this is not the syntax of SETRANGE
OnPush-trigger
CLEAR(ItemExp);
CurrForm.SETSELECTIONFILTER(Rec);
ItemExp.SETTABLEVIEW(Rec);
ItemExp.FILENAME('C:\test1.txt');
ItemExp.RUNMODAL;
Set use Request Form to No and Import to No in Dataport properties.
Thanks it is working with Item Form now.
What if i dont want to use rec i want to add a variable in global as ‘itemcode’
then user writes the item code in that field and then it will import. the form is not connected to any datasource.
