hello,
I am trying to make a report, I have a field that need to be calculated from another fields in the same records, I made the following function but its not working
Display Real TotalEx()
LedgerJournalTrans LGT;
while select ExchRate, AmountCurCredit, AmountCurDebit from LGT
return (LGT.ExchRate * LGT.AmountCurCredit) + (LGT.ExchRate * LGT.AmountCurDebit);
//return (LedgerJournalTable_ExchRate * LedgerJournalTrans_AmountCurCredit); // + (this.ExchRate * this.AmountCurDebit);
its a ledgerjournal report, (with few modifications happened already) I need to add a field that will be calculated from multiplying the debit or credit field by the Exchrate…
any advice…
thanks
Ahmad
