The single level will just do the top level Bill of Material whereas the Multi level with loop sub-levels to calculate the cost. The calculate standard cost updates the standard cost but you are using average costing. What are you tring to acheive?
Let me explain what is happening ? OR I am doing something wron g? Or I don’t understand the whole case of calc standard cost ?.
I am doing BOMX For an item X . one of those componenets is costing methode average cost and the standard cost was not filled .
First i filled the standard cost in item X . When i go to item X and do calc standard cost as all levels ;I was surprised not to calc the right standard cost at item X and at the same side the system deleted the stndard cost in item X . When i runned the calc standard cost as single level, it worked right .
Only I need to understand why this happened in this way ? As i understand or please correct to me that to do all levels must make the standard cost right .
What do you mean by “system deleted the stndard cost in item X” ?
To explain - the single level gets the cost for the items on the top level BOM and recalculates the standard cost for the item (item X in you example)
in multi level the routine goes down the levels and calculates the standard cost for sub-level items and then re-calculates the top level item. Having a sub-level BOM with costing method Average will not affect the calculation (although you will see the standard cost updated on the item card for this item).
what are you saying up , this what i was expected .
Strange! …to be deleted by system ? … the standard cost was empty in item card … try it if you want … having only average cost filled … after runnig the calc standard batch several time ,… and giving nothing … I went to fill the standard cost … YES If i run clac standard cost multi level …first it gives me wrong standard cost …Next it deletes the standard cost that i filled in item card …Vise versa if i run calc statement as single level … calc standard updated right and standard cost will not be deleted in item card …
First i was expected as you said above <<<<<<<<<<<<Having a sub-level BOM with costing method Average will not affect the calculation (although you will see the standard cost updated on the item card for this item>>>>>>>>>>>>>> But after what is happening in this case, I doubt in my knowledge to calc standard cost , and wrote this topic to know the difference . Do you think if the BOM is done only on one level … We must only run it as single level … and if we run it as multi it will give wrong …
