Hi All, i want to access the Navision-Tables from an other Programm (FoxPro) via ODBC. If i choose one table in the shown tablelist i get the following error: Connectivity-Error: [Navision a/s][Navsion Attain ODBC Driver]Unexpected extra token: . This is the exact error message. The last dot is also shown. If i try to acces the Data in CrystalReports everything works fine. How can i solve this Problem? We use Version 3.60 Thanks in advance. Regards, Frank
Now i have managed to get the Data out of Navision (Versions 3.60 and 3.70) with for example FoxPro, Access and C++. But if i want to save changed Data i get the error: Driver does not support this function. It seems that the DSN is opend read-only, though the read-only checkbox in the ODBC-settings in not marked! Any Ideas out there in the whole wide world? [:)] Thanks in advance. Greetings, Frank
You might check the odbc user permissions.
