Hello, When I configure a C/ODBC connection, you should give a company name. Is it possible to change the company when you use the connection? I must retrieve data from 3 company. And if I use 3 different connection, I have error. Is it possible to simply change of company? Thx
Hi, While doing the ODBC configuration don’t specify the company name.While connecting the database through ODBC connection can specify the company. Simultaneously you can not open more than one company in standalone mode.You need to close the connection and then open the other company.
