C/ODBC nav 2.6.0 on "modern" OS
Hello all,
A new customer of mine uses a very old version of Navision pre Microsoft era, they use Navision Financial 2.6.0 and use C/ODBC on a Win XP machine to get data from the Navision database.
We need this C/ODBC version on a somewhat newer OS to export the data however I don’t have any luck yet getting the C/ODBC to work. We still have the installer for C/ODBC 2.6.0 and I’m able to run the setup on Windows 8.1, I can add the ODBC as a system DNS but whenever I’m trying to use Excel as a test to use the odbc Excel crashes.
I know this is a long shot, and probably nobody uses this old version anymore and for good reason. But sometimes you come across a customer with very old software still in use.
The customer finally has come to the conclusion that “it works fine why upgrade” won’t hold up any longer.
