Dear all, I recently took over a database that has a customized table and page created for store requisition. This is to issue out spares parts items.
Now I am trying to build the item tracking functionality into it.
The problem is once I click on Item tracking Lines on the Store Req. Page, and the Item Tracking Lines page opens, the Serial No. field is not editable.
Any tips on how I can make this work please?
Dear all,
Anyone kind enough to respond? I still need your assitance in solving this.
Thank you.
It is likely that the Serial No. field on the Item Tracking Lines page is set as read-only. To make it editable, you can follow these steps:
- Open the Item Tracking Lines page in the development environment.
- Go to the Design mode of the page.
- Right-click on the Serial No. field and select Properties.
- In the Properties window, go to the General FastTab.
- Make sure the Editable property is set to Yes.
- Click OK to save the changes.
- Compile the modified page.
Once you have made the Serial No. field editable, you should be able to enter the necessary information for item tracking.
