Can anyone suggest me how to do build automation using DevOps?
In Detail: Actually we are doing check in the objects after the development has been completed. after that we will initiate the VSTS build then deployable package will create. this is the manual process. but i need if i will select on daily basis. it will automate the build. it is nothing but we will set triggers.
Deploy and use an environment that supports continuous build and test automation - Finance & Operations | Dynamics 365 | Microsoft Docs this i referred i need the steps to do.
Ramesh Lella.
