Bugdget sub model
I have issues understanding about Budget sub model. Can someone tell me with example the usage of sub model in Budgeting module in Ax 2012?
Sandeep
You can budget at sub-model level and then attach multiple sub-models to a top level model and where ever you use it it will bring all of the figures from all of the attached sub-models. It is basically a model, but a smaller subsection and one that can be attached to a model (it then is a submodel) to bring all elements into one.
Thank you Adam. Can you give me an example where sub model is used so that I can understand more clearly.
Sandeep
Create a sub-model budget for purchasing dept 1 and purchasing dept 2 - link them to the budget model purchasing dept
