Getting the bellow error message when trying to upload budget. Using the same old template which worked yesterday. Also, tried creating a new template by adding all of the required fields from the Budget register entries and Budget account entries tables (including the below fields) and keep getting the same error. None of the fields are blank when trying to upload.
| Field ‘Budget model’ must be filled in.Field ‘Budget code’ must be filled in.Error found when validating record.Field ‘Dimension values’ must be filled in.Error found when validating record.Field ‘Dimension values’ must be filled in.Error found when validating record.Field ‘Dimension values’ must be filled in.Error found when validating record.A budget code or budget type is required, and neither is specified. The budget register entry could not be created or updatedError found when validating record.Document Budget register entries could not be created. Error details: Error found when validating record. |
