What could be the possible relation between a project linked to an item that has sufficient budget allocated and financial dimension values for performing budget check process in a purchase requisition?
When we checked the budget check warning in the PR, it shows budget check failed against the dimension value. The dimension value has negative quantity when we checked the Budget control statistics.
So how is the project budget and financial dimension value budget related in this scenario?
