Hi all. Do you think its strange how the cosmetic changes (layout, lines etc) always take more time than the programming… Now I have used OLE-Automation to create a table in Word and of cource it has to have borders. Borders meaning lines and grids. How can I do that? Thanks in advance.
Think there is some sort of TableStyle or AutoFormat property you can set… I will have a check… A [}:)]
Yep… I do this using the AutoFormat method…
Thanks Akers. I tried the autoformat method but could not get it right. I found a way to use the Style method instead which was just as good. If you have the syntax, there it would be interesting to see how it goes [:)] Thanks again.
Hi… I don’t have any examples with me in the office at the moment but you might want to check out this link… It may help… http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dnovba00/html/TableStyles.asp Cheers Ade
