heyy … i am doing customisation on "BOM ConsistOf " form . I encountered with following error. what does it means.
Form BOMConsistOf requires an active buffer.
Double-click the error message and you’ll get directly to the place where the error is thrown, so you can see it by yourself.
The message means that the form is designed to be called with a buffer, i.e. with a table record (e.g. BOM). If you don’t provide this parameter, the form can’t work.
hey thanks …
am cleared with the above error .
