In blanket sales order suppose that two same item with different Quantity when its converted to sales order I want to merge both quantity in one line only how can do that the customization and where write a code.
Sorry Sunil,
not sure what you are looking for . Get a developer and have it done . This is pure coding req.
g.
You need to do programming for this while converting quote to order.
Any specific reason for merging ?
No. There is no standard function in W1 version. even if it is same item and same qty in same planned shipment date , system will treat as two separate lines because of you have entered it two separate lines at blanket sales orders.
Customization.
