Does anyone know what would cause this error when trying to create a company on the BizTalk server? I believe it has something to do with unregistered components but I am not sure which ones and how to resolve it. The error is: Could not invoke the member TransportType. The OLE control or Automation server returned the following message: The requested member does not exist, or the call tried to set the value of a read only property.
Did you make sure that you are using the right versions of the products that you need? For instance, up to 3.70A, Navision is NOT compatible with BTS2004. Also, did you follow all the instructions for setting up Commerce Gateway? This should take care of all component registrations that you’d need.
Thanks for the post Daniel. I found out that our Commerce Gateway was not properly installed and BizTalk 2004 is the version that we were trying to use. Does anybody know if any patches or hotfixes are available to enable the use of Biztalk 2004? We are currently using Attain 3.70A
Not that I know. As far as I know, MS has been busy with 4.0. I’d say that this is a pretty high priority issue for them though, as many of their customers will want to use CG with the latest version of BTS.
