If you are posting a bin movement but you have lines in the warehouse journal of template ‘MOVEMENT’ and the batch name is the same as the user who is logged in. You will receive an error. The error message will vary. In the code unit 99002499 Logistics - Integration - Function BuildJournalMovement. It tries to create a negative and positive entry in the warehouse journal BUT is unable to because they already exist on the warehouse journal, but it doesn’t give an error because of the "IF record.insert " statement is used.
Hi Jules Did you get an external response to this? What version was it?
