Bin content deletion
Hi Experts,
Can i delte the Bin content data for one item with stock - Zero?
If i delete the bin content ,is there any problem.?
Thanks and Regards
I guess you are using Fixed Bin system (Field Fixed Bin on the Bin Content should be checked). Otherwise it would be deleted autamatically…
If you delete it system will not know where to put this item when you receive it next time.
So:
if you do not plan receiving this item in the future or you will assign new Fixed Bin later you can delete it.
