Hi everyone,
I have a requirement to develop a custom Bill of material report in Dynamics AX 2012 that have the following capabilities.
Parameters: Item group(Done!).
Then the report should drill down and display bill of materials and sub level to the lowest level. Due to the level of complexity of the business logice required by such a report, I resorted to use a report data provider class to generate the data-set for the report.
Below find my code
public void start()
Query query = this.parmQuery();
//This method drills down the bom/WIP to the lowest level
void wipExplode( ItemId _wipItemId)
BOMTable wipBomTable;
BOMVersion wipBomVersion;
BOM wipBOM;
bomLevel =bomLevel +1;
//Declare query variables
while select firstOnly wipBomVersion where wipBomVersion.ItemId==_wipItemId
&& wipBomVersion.Active && wipBomVersion.Approved
//If there is a result type, then the wip has a bom.
// if (wipBomVersion.RecId)
while select wipBOM join wipBomVersion where wipBOM.BOMId==wipBomVersion.BOMId
if (wipBOM.ItemId like “W*” ){
wipExplode(wipBOM.ItemId);
else
this.popIntoBOMAnalysisByRMaterialTmp
parentBomID,parentItemId,
parentItemGroupId,parentInventDimId,
wipBOM.InventDimId,pmfBatchSize,
pmfFormulaUnit,bomLevel,
wipBOM.LineNum,wipBOM.ItemId,
wipBOM.BOMQty,wipBOM.BOMQtySerie,
wipBOM.UnitId,InventItemGroup::find(wipBomTable.ItemGroupId).Name
query.dataSourceNo(1).addRange(fieldnum(BOMTable, ItemGroupId)).value(queryRange(itemGroupId,itemGroupId));
query.dataSourceNo(1).addSortField(fieldnum(BOMTable, BOMId));
query.dataSourceNo(1).addSortField(fieldnum(BOMTable, RecId));
qr =new QueryRun(query);
while(qr.next())
bomTable=qr.get(tableNum(BOMTable));
bomVersion=qr.get(tableNum(BOMVersion));
bom=qr.get(tableNum(BOM));
inventDim=qr.get(tableNum(InventDim));
bomLevel =0;
parentBomID =bomVersion.BOMId;
parentItemGroupId =bomTable.ItemGroupId;
parentInventDimId =bomVersion.InventDimId;
parentItemId =bomVersion.ItemId;
pmfBatchSize =bomVersion.PmfBatchSize;
pmfFormulaUnit =bomVersion.pmfFormulaUnit();
if(bom.ItemId like “W*”){
//bomLevel++;
wipExplode(bom.ItemId);
else{
//Starts by populating the BOM header details
bomVersion.BOMId,bomVersion.ItemId,
bomTable.ItemGroupId,bomVersion.InventDimId,
bom.InventDimId,bomVersion.PmfBatchSize,
bomVersion.pmfFormulaUnit(),bomLevel,
bom.LineNum,bom.ItemId,
bom.BOMQty,bom.BOMQtySerie,
bom.UnitId,InventItemGroup::find(bomTable.ItemGroupId).Name
Logically to me, the code is logical but when I run the report, the AOS stops. The resultset also looks not realistic. the bill of material level is just incrementing and not maintain its respective level. The data also looks too much redundant.
Can anyone out there assist me point out what I’m doing wrong?
I appreciate alot.
Isaac.
