We are using Business Central 16.1; Is there professional document templates for Sales Order, Sales Quotes and Invoices? Are you simply modifying existing document to fit your company’s needs?
Hello,
In BC do the following to locate the standard BC Reports for the documents.
Go to Report Layout Selection. You will see all the reports for each Document to be run:
You can click Process, on the action bar, and see Custom Layouts.
You can them create your own in RDLC or Word. After you create your own, you attach the Custom version in the Report Layout Selection page.
Hope this helps.
Steve
