We need to generate Bar code and print the same. In Basic Module i setup the barcode setup and link the barcode to item master and setup the dimension also.
From where can i view the barcode image or print the barcode serial no etc. When i try to print from the inventory management reports lables> serial no - it generate the report but it can view the reports
I would also like to know if its possible to enter an order (sales/ purchase with a barcode scanner, so instead of typing the item numbers, i would like to scan the barcode on the item with a usb barcode scanner attached to my computer.
Thanks in advance.
Hi Abdel,
I hope you got your solution by now. I was able to generate barcode and even scan them onto the saleline or purchline using code. But i dont undersatand why Basic >> Setup >> Barcode Setup and also the Inventory Management >> Item details >> Bar codes is being used???
GuysPlease help am i missing something???
kaushik
Hi Kaushik,
We can attach a barcode with each item from Inventory Mangement>> Item detailes>>Setup>>Barcode instead of using itemcode itself as barcode.
Eg:
Item code barode
101 AB12
102 XYZ1
And we are using Basic>>Setop>>Barode Setup to setup barocde options like barcode font, size, lenght etc
We are mapping this option to Inventory Mangement>> Item detailes>>Setup>>Barcode
Hope you got the concept
Regards
Hi Kallil,
Thanks for a quick reply. I understood the concept. So we can have items tagged by other numbers other than itemid also, fine.
kaushik
Hi Kaushik,
Can you please help me by providing the code to generate the barcode and scanning the barcode and also I have doubt that how are scanning the barcode on any paper.
If anyone have code for the above requirement can you please send the xpo to saiharish213@gmail.com.
Thank you very much in advance.
regards,
Harish
The bar code excel 2007/2010 add-in is easy to print UCC/EAN-128, Easily generate barcodes in Microsoft Word and Excel with this Bacode Add-in.
i want to receive and issue inventory using barcode scanner from ax in ax 2012 r2, can you tell me how to do it. i guess i did it once and it worked but currently when i am scanning the barcode, it is reading the barcode but its not briging the pitem associated with the barcode and instead shows an infolog that states that there is no such item “#########” it is considering that barcode to be the item code. can you help me in this please?
[ Advertisement removed by a moderator. Please contact the administrator if you want to advertise on this site; abusing the forum isn’t acceptable. ]
Suddenly this person and Slavica creates a lot of replies and promoting a certain add-on related to bar-codes. Are they really a happy customer or are they working for the company whi sells this product? Can an administrator have a look?
