I’m trying to import a csv with only 4 lines. I’m receiving the error message in the first image. And the last image shows the current data exchange definition. Anyone have any ideas to resolve this?
Hi @GreenSquare,
Please check that file type is “Variable Text” and column separator" is “Comma” for that data exchange definition.
Hi @pjllaneras
It is indeed both as you described.
Try changing the yyyy/mm/dd to yyyy/MM/dd. mm is generally minutes, not months.
