Hello!
We are experiencing a difficulty. Most (not all) of the Journal Entries using the Bank Account do not appear in the Bank Account Reconciliation Dynamics NAV 2013 component. Even if we use the same way for our Journal Entries, some of them are present.
In my search, I did not find any solution that applies to us:
1-dynamicsuser.net/…/169965.aspx (Our Journal Entries comply as suggested in this discussion)
2- dynamicsuser.net/…/180758.aspx
3- We also make sure to refresh the information with the “Suggest Lines” process.
How can we solve this challenge?
Thanks for your help!
Sylvain
Thank you for your question. When you have already tried what normally is suggested, then it’s difficult to come up with something better without actually seeing your system. So I hope you found a solution since you asked your question. If you did, please tell us your solution, so that it might help the next user with this problem.
If you haven’t found a solution by now, then I will suggest that you take the entries that works correctly and compare them to the ones that doesn’t work. What is different? Have they been posted differently? Different currency, different bank?
Check is there any open bank reconciliations are open for the bank - This might cause the issue since entries are already been booked by another reconciliation .
Date range of your reconciliation .
Other than above mention points as Erik said check and compare the entries (which come to bank Reconciliation and which are not).
Effectively, since we had many monthly bank reconciliations to catch up, we began to work on some monthly bank reconciliations at the same time (cleared deposits and withdrawals). So, some months were still open. When we deleted the reconciliations and worked in a chronical order, everything worked perfectly!
