Balance Sheet question
Hi, I have finished to create my Balance sheet ( around 110 lines) BUT Instead of using “Beginning Balance” in the “Row type” column , I used “Net change”.
I need to see the balance sheet at december 31st 2010; I also want to see my Income statement for the period between 1st january 2010 to 31st december 2010 ( in that case my row type was net change.
Any help will be appreaciated.
You can (and you should ) have different Columns Layouts for Income Statement and Balance Sheets.
In Column Layout, Column Type:
for BS, commonly will use Beginning Balance, Balance at Date
you may have 3 columns to show the changes:
Beginning Balance > Net Change > Balance at Date
Again, these are Column Type settings
Thanks Rics. What happen if I didnt use “Balance at date” in the column type. Do I need to rebuilt mt account schedule or I can still see amounts using date filter???
