Hi Guys, I want to ask if there is any way in navision version 4.0 how to display picture on the background next to the Navigation Pane? In the old version it was OK to do in the main menu but navision 4.0 has only left pane. I just want to show the company logo in the background once the user open navision. Or is there any other way how I can do this? Thanks.
If it is really really worth something to you, it can be done with API function FindWindow.
Hi there, Its pretty easy to work around Navision even after Microsoft took over. Try this sample FOB objects. I put something like this out about 3 or 4 years ago when Attain came out. The image will be a form to appear using the codenit 1, after the user logs into the system. The form will expand to the widest and display the company logo, but the user will not notice it as a separate form. If the user presses escape a few times the screen will disappear, but will return again upon login. Enjoy (Let me know if that is what you’re looking for. P.s. The file was zipped, Also in the main downloads at http://www.mbsonline.org/forum/file_library.asp?showmethecat=14
Hi, I am looking for this too. But I can’t found this sampel FOB from http://www.mbsonline.org/forum/file_library.asp?showmethecat=14 Anyone can help? Thank you very much! Have a nice day!
