Hi I have designed a cube based on sales line table & it’s working fine.
Now i have added one more dimension which is linked with other table having more then one key in primary key. Now i again run the configurator it’s gives me error. SSIS Error Index was out of range.
I tried to change the Primary key to single the it s work fine. Very Strange…
DO some one have faced this issue before… Please help
SQL 2005, NAv 5 sp1
Ashish
