Axapta
Hi Friends,
i am new to the axapta
i have a form this form having the fields(Order id, Order Description , OrderDate , Priority ,ExpiryDate )
priority having enum fields like Vital,Desirable,Expansible Look up fields
My Requirement is when i am selecting the vital priority Expiry= OrderDate>=Expirydate<=Orderdate+7 ,
if i select Desirable Expiry=OrderDate>=Expirydate<=Orderdate+15,
if i select expansible Expiry=OrderDate>=Expirydate<=Orderdate+30,
by default orderdate=systemdate please send solution with coding urgently
Hi Sreenu,
Write code in Active method of datasource.
YourTableName.OrderDate = SystemDateGet();
If(YourTableName.Priority == Priority::Vital)
YourTableName.ExpiryDate == OrderDate>=Expirydate<=Orderdate+7;
elseif(YourTableName.Priority == Priority::Desirable)
YourTableName.ExpiryDate = OrderDate>=Expirydate<=Orderdate+15;
elseif(YourTableName.Priority == Priority::Expansible )
YourTableName.ExpiryDate = OrderDate>=Expirydate<=Orderdate+30;
Note: wirte Base enum in place of Priority that u have use .
hi sreenu,
write the code which rajkumar sent in priority field modified method in datasource fields, and in data source active method, if u modify the field…
once again after opening the form…
