In our Axapta setup, we have tested with Indian license (en-in) and it is working fine. Then we tried the same for another user by configuring the Server and Client configuration settings using the setup in the respective login, it is throwing the following error “No Lincese available for the language code EN-US.”
Server Configuration : Server name - Server1 and DB - AX2009; Port No - 2713
Clientt Configuration: Server name - Server1 and DB - AX2009; Port No - 2713
Configuration command to run at Kernel startup - “=language-en-in”
Above are the setups done for the user but could not login to Axapta. Please suggest.
i have one doubt userinfotable and sysuserinfo tables are same? In the sysuserinfo table there is no lanugugae field? So please clarify me where is userinfo table?
UserInfo contains list of users in AX and their Active Directory info and default company info. In DAX you can see this table under System documentation > Tables in AOT
SysUserInfo on the other hand contains info related to user option settings for each user. You can see this table under Data Dictionary > Tables node in AOT.
For the language issue (as I suggested in my previous post) the particular user’s record may be modified directly in SQL Server. The ‘UserInfo’ table should be right at the end in SQL Server → → Tables node
Alternatively an AX job may be written to modify the particular user’s language setting.
