Could anyone give me an idea about how to go about doing the Axapta Certification? I am an Axapta Developer working in an NSC in India. I do not have any idea about the papers, syllabus or how to go about preparing for the exam. Can someone help me out?
Hi Ayan, The certification that a technical person can do for Axapta is as follows : 1. Axapta General Application test (W1-AX00010) 2. Axapta Programming (W1-AX05010)(Pre-requisite Exam - 1) 3. Axapta General Technical Test (W1-AX00011) 4. Axapta Database (SQL) (W1-AX05020)(Pre-requisite Exam - 3) 5. Axapta Database (Oracle) (W1-AX05030)(Pre-requisite Exam - 3) 6. Microsoft Certified Professional (70-215)(Win 2000 Server) 7. Microsoft Certified Professional (70-216)(Network Infrastructure - Win 2000) 8. Microsoft Certified Professional (70-218)(Active Directory) 9. Axapta Server (AOS) (W1-AX05050)(Pre-requisite Exam - 3,6,7,8) 10. Axapta Web Applications (W1-AX05040)(Pre-requisite Exam - 3) For further details like the certification requirements, passing percentage and the Exam course, kindly contact your NTR in India.
hi ayan, Which NSC are you working. I am in Delhi working with sofosphere. You need to go through the e-learning complete of all topics for general application test. Also have your hands on the product for minimum two months and go through field by field by right clicking & checking out “What is this?” For Axapta programming u need through go through advance X++ and Morphx Integration documents, but the Main is Axapta Developer guide. Go through the Axapta developer guide throughly. wish you all the best regards Vaibhav Pednekar
Thanks for the info. I am currently working in Pricewaterhouse Coopers in Kolkata, India. We are implementing Axapta for a Kolkata-based client. Could someone please suggest which set of papers I should appear for first? The problem with preparing for these papers is the lack of availability of study material - will the e-learning tutorials suffice for the general application test?
To start with you can clear your Programming Certification which is simpler than the rest. For the General Application test the best source is ur e-learning CD. Then you can get more help from the essentials pre-test in the http://training.navision.com . Once you are able to score 90 % and above in this test then u can be confident enough that u surely would pass the General Application Test. For the Programming Test, u have to go through the developers guide and the study material that wud had been provided to u in the training from ur NTR or MBS office as the case may be. In case u did not recieve the material then u can ask ur NTR/MBS office for it. Also some hands on experience would be required to answer some of the questions. wish u all the best and hope that u get through ur certification soon.
Does anyone have a pool of questions for the Ax-50-010? Or knoes where to get one???
Yes!!! Passed the programming test! Working on Trade and Logistics. Anyone took this test? If so , on the scale of 1 to 5, how tough was it? How many tries did it take to pass?
Could somebody help me where can I find training materials to General Technical Test (W1-AX00011)? What documents are required to know for this exam? Thanx in advance, dris
If someone has passed the programming test, can he/she tell me what kind of questions were asked? I would like to know the level of difficulty as well as some sample questions.
