Can use Resource option with only Production I license ? Production II brochure say need Production II to use Resources. thanks
hi you can purchase resource module license, but look into the requirement. It is For Production II the pre-requiste is resources. SO if u go for complete production I & II then u have to get resources also Resources are also the prerequiste for Projects Series. thank you regards vaibhav
thanks vaibhav for your answer. I have Resources license and Production I. No Production II license active. With this configuration axapta have Resource Option into Base Module. Resources option is available for entry data. But in Production Module, in Production Order it is not available Button with Resources Option. Where can make relation between Production Order and Resources assigned in resources option ? thanks again
