turgut
#1
Hi there I need help !!!
My problem I have a form and forms’s tables example XForm Dotasourse Table1 Table 2 Table3 its ok no problem here
But ı need ı add one fields Table4 to XForms and adding fields can filter
How can ı this task without using display method()
Im waiting your ideas Thansk For helps …
KindRegards
If you don’t want a display method, you need an additional datasource for Table4.
turgut
#4
I add table to datasource but cannot see on grid
ı cannot use displaymethod becouse wanna filter this fields
Thnaks For idea
after adding the table4 into datasource, you need to set the relationship to other tables, and then add the fields you need into grid.
