AX2012 SSRS Reports
Hi Friends,
How to filter the data in SSRS?
I add CustTable Query in VisualStudio Report DataSet.I want to display data based on Account numbers
Hello Kishore,
You can do it in two ways.
  1. Add Accountnum field into range node in AX query
  2. You can also add parameter in visual studio in parameter node .
Hi Rajkumar,
How to add parameter in visual studio?
I try to add but i confused to set the properties in parameter
Kishore
Hello Kishore,
First go to the parameter node and click Add new parameter and rename it then go to values in the properties then click fromdataset and choose a dataset and into data field select Accountnum. After that u have to add a filter also go to the filter node in the design and add a filter here u can see 4 properties in the expression select AccountNum and in the value property select parameter which u add early for AccountNum u can find it at last in the dropdown of value property.
hope it will help.
Hi Rajkumar,
Thanks a lot for giving replay.it is very helpful for me.
