However, my fear in allowing blank issue/receipt is that an inventory transaction will be posted without location thus I can no longer trace the location of each item.
The work-around that I’m thinking is to make the location mandatory but this is quite tedious cause I have to do this in every form.
Is my idea correct? Or is there any other way of blocking posting without location should I choose to mark Allow blank receipt/issue in Location?
Thank you, Marty… It should be posted on other question.
BTW, I made a simulation of direct delivery today.
I did a transaction from direct delivery using the Storage Dimension with Accept Blank Receipt/Issue in Location & I succesfully created intercompany direct delivery.
Scenario:
Branch creates a Sales Order to a Customer
Branch creates a Direct Delivery to Head Office. Consequently, an intercompany PO & SO was created.
Post Pick List & Pick List Registration in Head Office.
But when I’m posting the sales invoice in Head office, I am encountering an error “The result of Invoice matching process for invoice XXX is unknown. View the invoice in te posting invoice form or perform invoice matching on the invoice and then post. Posting of POXXX canceled.”
I checked the PO of the Branch to HO but the invoice is disabled since it is a direct delivery. I also changed the AP Parameters not to require invoice matching but the result is the same. I also did check the Intercompany PO setup.
Have you also encountered the same error? What might be the cause?
Thanks for sharing your knowledge.
However, I have a problem with Inter-company Direct Delivery. The case is Company A sold to the external Customer, then company A order it from Company B, a sister-company. Company B directly deliver it to the external customer.
I managed to do this with non-serialized items. However, when I’m dealing with serial number-controlled items, it blocks posting of Packing Slip in Inter-company SO. I need to register the serial number first in Intercompany PO then repeat again in inter-company SO picking list.
I tried to synchronize the serial numbers but it requires issue status “Deducted”.
AX will also accept different SN received in Intercompany PO compared to what is delivered in Intercompany SO.
