Hello,
I am using AX2009. I define a workflow on salesTable, such that users need to approve before posting invoice.
I have two outputs - Approve or Reject.
I encounter a problem of workflow status.
Whenever managers reject, the workflow is still running.
When workers re-submit, the salesTable has two workflows running. The first one is the original workflow, the second one is the re-submit workflow.
How can I avoid two workflows?
In my case, when workers re-submit, AX should continue the original workflow.
Thank you in advance.
