The message is clearly indicating you to fill the batch and serial numbers which are mandatory to input as per your Tracking dimension group settings. Just try filling them up and you will have no more such errors.
If you are unable to view these fields on your w/o form use Inventory=> Dimension display (or Dimension display) option to view and select the dimensions for entry.
Have you posted a picking list journal/have the RAF tick ticked at end? So in other words have you consumed all the material you should have at this point?
That is not answering my question - you can RAF without consumption, but if the pick lines do not have the end job set you would get that error message.
