Hey
I’m currently trying to set up a debugging enviroment on POS 2009. I have used this enviroment before, but now I have a problem where the POS tries to load all the peripherals when I debug. Is this normal when debugging the perpherals project?
The problem is that I have no peripherals connected, and therefore I get the following error:
System.IO.FileLoadException: Could not load file or assembly ‘Interop.OposScanner, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. Strong name validation failed. (Exception from HRESULT: 0x8013141A)
File name: ‘Interop.OposScanner, Version=5.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ —> System.Security.SecurityException: Strong name validation failed. (Exception from HRESULT: 0x8013141A)
The Zone of the assembly that failed was:
MyComputer
at LSRetailPosis.POS.Program.Application_ThreadException(Object sender, ThreadExceptionEventArgs e)
at System.Windows.Forms.Application.ThreadContext.OnThreadException(Exception t)
at System.Windows.Forms.Control.WndProcException(Exception e)
at System.Windows.Forms.Control.ControlNativeWindow.OnThreadException(Exception e)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at DevExpress.Utils.Win.Hook.ControlWndHook.CallWindowProc(IntPtr pPrevProc, IntPtr hWnd, Int32 message, IntPtr wParam, IntPtr lParam)
at DevExpress.Utils.Win.Hook.ControlWndHook.WindowProc(IntPtr hWnd, Int32 message, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.SafeNativeMethods.ShowWindow(HandleRef hWnd, Int32 nCmdShow)
at System.Windows.Forms.Control.SetVisibleCore(Boolean value)
at System.Windows.Forms.Form.SetVisibleCore(Boolean value)
at System.Windows.Forms.Control.set_Visible(Boolean value)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.Run(Form mainForm)
at LSRetailPosis.POS.Program.Main(String[] args)
If I start POS directly withot the Peripherals project, it works great.
