[AX2009] "Out of memory" and client cache
I’ve following problem: sometimes, on a few client machines I can not start MS Dynamics AX2009. Application shows error “Out of memory” and then closes.
After I clean local client cache, application starts with no problems.
Does anybody know what is cause of this problem?
arnam
Hi arnav,
if got the answer for this, pls tell me
Unfortunately I have not found any other solution for this problem.
We had a similar problem, and our retailer provided us a microsoft hotfix to install : KB960849, it solved our problem, no more messages,you should have a look at microsoft.com
Hope it helps
Thomas
Hi, Thank you - I will try this hotfix and let know if it helps. Regards, arnam
