Hello,
Is something knows if AX 2009 supports Active Directory 2000 when the client
is installed on a Windows 2008 machine ?
Config :
AD 2000
SQL 2005
AOS on Windows 2003
AX client on Windows 2008
Thanks a lot.
RV
Hello,
Config :
AD 2000
SQL 2005
AOS on Windows 2003
Thanks a lot.
RV
I think it might working with Active Directory 2000.
Because in minimum requirement document they just specify that only Active Directory service is configured in the sysytem.
so you can use Active Directory 2000.
If you configured successfully then give me answer.
Janak Talekar
hi,
I found an article on the Internet.
Those people are using Active Directory 2000 with DAX 2009.
so you can also configure AX 2009 in Active Directory 2000.
You just see that artivcle on following link
http://www.eggheadcafe.com/software/aspnet/33522104/dynamics-during-win-2000.aspx
Rerards,
Janak Talekar
Hi Janak and thanks for your 2 responses,
It seems to work with this config :
It doesn’t wotk with this config :
Only one thing has changed… → OS of client AX2009sp1
Thanks a lot !
Herve
Are you install SP1 on AOS or not ?
Janak Talekar
Janak,
Yes : SP1 all on AOS ans client
en_dynamics_ax_2009_x86_dvd_x14-85054 for install Sp0
DynamicsAX2009-KB956568.EXE for SP1
All seem to worh when I install AX Client SP1 on windows 2003
But we would want to implemante on Windows 2008 the Ax Client !
Thanks for helps
