There is work flow resume button in work flow history form(in basic module). What is its exact usefullness/functionality?
if it starts the work flow again then does it requires submition and approval once again ?Please explain with appropriate ex.
What actually happened when you pressed it?
It is resumes the workflow with faulted status…
it helps to reset the workflow which is stopped with some error …(status = Stopped (Error))…
Hope this will help you
Regards
Kranthi
I think it then tries to process the work flow again. i guess it won’t require submition and approval of W/F again …Can someone throw some more light on it [:)]?
I think that has already been done. Resume when it has failed for a reason - carries on from where it failed.
