I want to know what AX version will be install with which OS version.
like can I install AX 2012 with Windows Server 2008.
Yes you can install 2012 on Windows server 2008 only 64 bit OS.
To know the AX version , just go to help of AX and select “About Microsoft Dynamics AX”. Here you will get AX version and kernal version as well.
Microsoft always publish a document with system requirements. The one for AX2012 is here: Dynamics AX 2012 System Requirements.
You should refer Microsoft’s system requirement of the AX version you would like to proceed with.
Thank you
