AX Service crashes while removing the line on Purchase Order
AX Service crashes while removing the line on Purchase Order:
I am Performing these steps-
  1. Created purchase Order with 1 qty of Item.
  2. Purchase Order is approved [Because of workflow activation]
  3. Confirm the Purchase Order.
  4. Do the registration of 1 Qty.
  5. Do the request change [because of work flow activation] to edit the PO
  6. Delete the Purchase Line which was registered earlier.
  7. AX service is stopped.
Please let me know if anyone has faced similar kind of issue. Is this a Bug?
What the Microsoft AX Product says because neither it gives any error message while removing the line nor the remove button is disabled.
Please tell us where exactly it crashes. Use the debugger to find the place.
