I am running local VM to access AX RTW. I am getting lot of issues there.
I have a perfectly working internet connection in VM. My company uses proxy to access internet, so there is a proxy setup that cannot be bypassed.
Now the issues:
- When trying to open a URL https://usnconeboxax1aos.cloud.onebox.dynamics.com/ getting a connection issue
This page can’t be displayed
•Make sure the web address usnconeboxax1aos.cloud.onebox.dynamics.com is correct. •Look for the page with your search engine. •Refresh the page in a few minutes.
Fix connection problems
- When running Admin provisioning tool, entering my Office365 ID(which I use to access AX deployed on Azure), on pressing OK I am getting and issue as
The remote server returned an error: (407) proxy authentication required.
I’ve tried to find out and resolve 2nd issue, but could not get anything as I cannot bypass proxy and so need everything to work with proxy connection.
Also, I started Azure emulator inside VM.(By default emulator 4.0 was installed, when tried to start, it was not starting and was targeting to some network location for installation media. So, I’ve downloaded and installed emulator 4.4 there, it started successfully.)
Following https://ax.help.dynamics.com/en/wiki/access-microsoft-dynamics-ax-7-instances-2/
and few other blogs
http://tech.alirazazaidi.com/running-dynamics-ax-7-ct8-vm-on-windows-8-1/
https://community.dynamics.com/ax/f/33/t/192422
Thanks in advance.
