I am getting this error while testing connection of HQ location to the HQ store connect for which there is not much in the documentation and neither it gives error message in Event Log. So please help. Its quite urgent.
8192: An error occurred in processing the request.
Am also trying to configure ax retail, till now am not able to send data successfully to store database.
Retail store connect profile,AOS Profile and database profiles were set in my machine, and whereever i do test connection, its showing successfully connected.
but data is not going to terminal after even manually running those jobs
I am busy installing Retail and I am running into issues with sending data down to the POS database. Please can you help me?
We have the following setup: 1 AOS, 1 HQ, 1 POS Terminal. thus we have 2 machines. The store connect is installed on the HQ and the POS Terminal. Must we configure the store connect on the POS Terminal?
We did the configuration for the store connect on HQ. When we setup the Store Connect Profiles, AOS, Database Profiles what should we setup in each?
Store Connect Profile - the Instance installed on HQ or POS Terminal?
AOS - The HQ Instance?
Database Profile - The 2 database - HQ and POS, is this correct?
Am installed Ax 2009 retail r2.Store connection & Data base profile is connecting.but when am going to connect AOS profile.am getting ERROR 8192:Error in Processing Request.
Does anyone know what I need to do to correct this issue?
Has anyone figured this out yet? We just moved our AX environment to a new server and now have the same 8192 error on the AOS Retail Store Connect profile only. All the connections to the remote store terminals work fine.
