Dears,
In Ax reports,i have display the itemcode ,itemname,inv_qty.while i converting the report as pdf,itemname and inv_qty are mixed…Need solution for this…please find attachment for your reference.
Dears,
Plzzzzzzzzzzzzzzz Helpppppppppppppppppppppp ?
You have a few options:-
hii,
thank u for ur reply. i tried but it not working…
This is a spacing issue, when you move things over the fields gap must get larger.
If you are still having issues I will take a look at the XPO if you want as it should be simple to fix.
hi
sorry for delay reply…the issue has fixed its working fine.i made a mistaken for set the itemname height column width,i changed this to auto and then set the dynamics height yes.its working fine…thanks a lot.
Its ok bala… If u have any doubt in dynamics… call me i will clear you
